1 - 19 of 19 Posts
its blingtiffic™
Home Depot hot water kits and some foil tape;)
Turbo boosted
lowes, go to the hvac section and get the duct wrap. looks like silver bubble wrap!
Turbo boosted
never tried it with out it, always been on the cooler,pipes,water tank, never had any sweating issues. start out at 33degrees and get to about 60-70 at the end of the quarter!
Is that water temp or air temps?
Turbo boosted
air temps, at 39lbs of boost.
wow, i'm impressed
(i'm just getting into this intercooled boosted world, learning alot)
Here's what we used last year on the intercooler. http://www.summitracing.com/parts/THE-14620/
On the ice tank we used the water heater insulation which by the end of the year was getting wore thru and ripped up.
The thermo-tec stuff is a pain to get off but we did remove it so that we could combine the intercooler and tank this year.
Discussion Starter · #13 ·
thanks for the input! a friend of mine (who is doing the welds on my tubing after ive tacked) has stuff at his shop called lizard skin http://www.lizardskin.com/pages/ceramic.php that he wants to spray on the hot-side tube, because it runs parallel to the floor & carpet and under the seat, and obviously whether i wrap it or coat it, whatever I do im thinking ill need to do something no matter what to keep the carpet from being burned or melted...
Yea doesn't the Lizardskin also stop the sweating?
its blingtiffic™
What's it weight in the typical application?
where is this pipe running??...inside the car, why...
Discussion Starter · #19 ·
umm coming from supercharger thru firewall to the intercooler in the back....... its a streetcar and very large intercooler, no room for it in engine compartment...............
1 - 19 of 19 Posts
