1 - 1 of 1 Posts
1-877-MOD-POWR
MMR Inline Thermostat Housing/Bypass Line delete with 1/2 NPT Port
Can be placed in upper or lower radiator hose, great for removing complicated and bulky lower radiator hoses . Perfect for removing factory bypass lines or to add one. The port can be plugged or also be used for a coolant temp sensor if needed using a 1/2npt to 3/8npt reducer.
  • For 1.5" Hose (in and out) or -16AN (in and out) OR COMBINATION
  • Can be used to Adapt -16AN to 1.5" Hose
  • 1/2 NPT Bypass or sensor port
  • Leakfree O-ring design
  • 100% Made in USA BY MMR
  • Accepts traditional Thermostats/gaskets (not included) (Small block Chevy Thermostat & Gates 33616 rubber gasket)
  • If you do not wish to use the port, it can be simply plugged using a 1/2 NPT plug fitting.
  • Part easily unbolts for Thermostat installation or replacement
ORDER NOW: MMR Inline Thermostat Housing / Bypass Line delete 4.6 / 5.4 [966542] - $57.99 : Modular Motorsports, Home of the Worlds Fastest Modular Engines
1 - 1 of 1 Posts
