1 - 5 of 5 Posts
This motor is built and next step is turbo pipe fabrication. Original plan was Ignite E90 and a Chiseled ATA 1500hp intercooler. Thinking was this might be a dragweek car, but that won't happen. So now debating setting it up for methanol without intercooler. When I put info in the calculator, looks like I need ~400 injectors instead of the 220's I own. Or I could pay to have my Hiram modified to 16 and put another set of 220's in. New to turbos and not sure whether making the switch makes sense as I already own the ATA intercooler, but was going for simplicity in turbo routing Opinions? Do I need that much injector? Full Specs of motor, plan is to cap boost at 30 psi as it is not o-ringed.
Block - Iron Eagle SBF 9.500
Crank - Callies Magnum 4.125/2.1
Rods - Oliver Heavy Duty Billet 6.2
Heads - TEA 250 Highports, 1.6 TD Shaft Rocker, PAC 1226 springs, 2.125/1.6, Morel Lifters, 57cc chambers
Holly EFI Dominator
Siemans 220lb Injectors
Danny Bee Belt Drive
Russel R4 External wet-sump
Holley Hi-ram Compression 10:1
7500 rpm redline
Powerglide
Garret gtx5533 94mm
Running a mechanic fuel pump you could pulley it for 95-100psi fuel pressure which would extend those injectors a long way
2x sounds right, many injector's struggle over 75 psi of pressure difference. ymmv
1 - 5 of 5 Posts
