1 - 17 of 17 Posts
what kind of injector driver would i run if i wanted to run large injectors with a stock ls1 ecm so i can run E85?
out of work hair dresser
There are several out there but I've used the Acceleronics VersaFueler the most and never had an issue.
I have used the AEM 10 channel box's on so many cars now I have lost count. Speectech even makes a plug and play wiring harness for it.
Wow, I just looked at the link, are they fucking crazy, $200!!!! Fuck that, I'll do a little cutting and splicing at that price, I didn't even pay that for the box itself!!!!
Connectors aren't cheap. I know I build my own harness's
Not to mention that that is a wiring cluster fuck as it appears that both harnesses have to be used (stock and this one).
I mentioned it. some people prefer to literally plug and play. I personally intercept the wiring at the ECM and add new pins and extend down to the driver and pin that in it. Look factory when its done.
I'm almost done with my conversion to E85. I wound up getting a set of Seimens 80lb high impedence injectors.
What's your motor combo? Power adder?
90's or 120's is a big difference. What injectors were you running before the E85 conversion?
Those 80's might not be enough to run the times in your sig.
Ive been 147 mph on e85 fuel and 80's. There are options for 100 lb injectors and 200 lb high impedance injectors also.
1 - 17 of 17 Posts
