1 - 20 of 31 Posts
looking to build a new engine for 8.50 class
have a mustang cm cage cert to 8.50s and all wolfe craft suspension glide t brake ect .......
have chance to buy a 363 and maybe spray it depending on heads
also know of a iron headed 532 bbf and could be sprayed .....just wondering power it would take thanks
In my experiences you'll need alot more than 800 HP at 3000 lbs. I'd say you better have 1000 hp or close to run that fast in an index class. You have to run the number in any weather and under any track conditions so you have to have enough to slow it down in great conditions so you got enough under poor ones.
My 582 dyno'd at an honest 1056/811 and the car has runs 8.50's at 158-159 at 3258 lbs.
Now, to be competitive at 8.50 you need to run that number in all weather conditions, to it's best to have a car that'll run low 8.4's to mid/high 8.3's and detune for conditions.
I'd say your gonna be looking at making a solid 1000 hp to run the number at 3000 lbs. 800 hp will likely only get you 8.9 to 9.0's.
T/S 368E
My 3200 lb car took 1050 HP to run 8.57, but it was not the best leaving car so take that into account.
My 3000 lb car ran 9.30 with 800 HP.
My 2600 lb car ran 8.40 with 850 HP.
Discussion Starter · #11 ·
if i was to use that dart 363 i talked about in orig post .........with good heads using an applied nitrous plate crossbar (jeff prock) think the sbf could make enuff steam to run 8.60s ect to qualify to run in that kind of index
the 532 is a production block even tho someone did 4 bolt caps ....seems i wouldnt think it handle that much vs the 363
andy do you ever make up your mind haha, you will need around 950 to be there and competitive to be honest, the 363 will obviously need high compression and maybe some highports or better with a hit of spray to get that number good luck bud hope you can get it there
also sucks but my c/m cage is only cert to 8.50s
i wouldnt worry about that. its why the class exist. they aint going to bust your balls if you go a 8.45 in a 8.50 index
And what is the idea of this in an index class? Do lighter lower HP cars have a huge advantage?
1 - 20 of 31 Posts
