Stenod and those guys can push the stock pcm very far, that's for sure. But I think most other high hp combinations use big stuff 3, accel, or fast with big stuff 3 being the leader of the pack since it has a system specifically designed to work with the stock COP setup and even use all factory style sensors if desired.
I'm running big stuff 3 but it hasn't been fired yet so I can't tell you much more than that...most people use the stock gm truck coils although msd does make a set of aftermarket coils ($$$), just no use using them since the truck stuff and even stock stuff works fine.
