1 - 5 of 5 Posts
got a blow thru that i cannot get idle to calm down on. checked everything for vacumn leaks , timing is 12 btdc had it apart as thought secondary plates might be sticking seem fine , float level comes just above glass if you rock car, got 18 showing on vacumn gauge and 6.5 pv so dont think that can be opening now if I shut primary plates down idle goes up any ideas cheers
Spray the intake to make sure it is not leaking at the heads.
I had a similar problem and it was the secondaries. Checked the transfer slot and is much better. Still can't get it under 900rpm if I wanted tho
thanks will have to pull carb apart again, if I pulled of carb hat can i let it idle to look inside
1 - 5 of 5 Posts
