1 - 7 of 7 Posts
"Darkness"
What is the ideal LSA for a sbc with a plate system capable of 300 wheel hp?
I get many different opinions about this. Here is what I have:
264/272 dur. 108 lsa .630/.630 lift
Spraying 200hp with a NX plate I run 1.3 seconds and 15 mph faster in the 1/4(9.50 at 140).
Recently I sprayed it 250hp and picked up about a tenth and 3 mph in the 1/8.
Is that a good gain or not really? Would I see a bigger improvement with a 110 or 112 lsa?
Administrator
:oops: sorry I missed that one...
I would go with a 112 for a 300 HP shot. The car will not run the number on motor but will run a better number on nitrous. You will have a hard time with a 110* on a 300 shot..
Administrator
Or you can read this in depth article which explains that LSA is not the only factor when selecting a camshaft...
http://www.chevyhiperformance.com/techarticles/95298/
Also selecting a camshaft depends on a lot of things like.. Car weight, convertor, heads, tranny.. etc etc.. most of the time it is best to call a cam company or someone with a lot of knowledge in this area. What works for one car will not always work for another..
1 - 7 of 7 Posts
