hi guys, i hooked this up in my dads car and it has no spark. so there are 2 wires that plug into the distributor cap(where the coil is) and there are 2 wires that hook to the pig tail on the module. i unhooked all 4 wires and plugged the pigtail from the module back into the cap(where the coil is) i tried starting the car then and it started.when the 4 wires from the box are hooked up there is power going into the distributor through the module pigtail but there is no spark and i checked it with a light so im sure there is power. so if it has power going into the distributor what could it be. also the box is all lit up and working. is the box not compatable with a gm delco distributor or something. the module and the coil are both flamethrower units. any help would be good.
Cody
Cody
