1 - 20 of 74 Posts
Here's my combo and I think it should be running a little better. I was hoping for 9.80's but only could get a 10.17 out of it.
436 SBC
Motown block 4.165 bore
Moroso stroker pan, Moroso wet sump oil pump, System One filter
Compstar 4" stroke crank, BHJ balancer
Callies 6"rods
J&E pistons 13.3:1 calculated compression, piston is .015 in the hole
Brodix -10 heads 2.08 1.65 mild gasket match and bowl work, 68cc chambers
Comp Cams custom grind 4/7 swap .900 base circle
Lift .697 int, .672 exh.
[email protected], 274 int. 284 exh.
106 int. centerline, 110 lobe seperation
Isky red zone solid roller lifters .300 tall
Procomp 1.6 rockers with stud girdle
Ported Victor Jr. intake
950 HP carb 78 jets w/2.5pv front, 88 plugged rear. 2" aluminum open spacer.
MSD 6al Ignition, Blaster II coil, 85551 dist., MSD wires
Moroso Vacuum pump
Hooker Super Comp 1 7/8 headers, 3 1/2 Dynomax Bullets
Turbo 400 w/5400 Coan converter and Coan Pro Brake
12 bolt, 4.56 with Strange spool.
Mickey Thompson 28x10.5 w's with tubes, 11 psi
68 Camaro 3060 lbs with me in it
I leave at 5400 and shift at 7500
Timing set at 38* locked out.
Run on Torco 110
Best pass so far is a [email protected], 1.34 60'
Try short shifting the 1-2 shift by 1000-1500 rpms. Your car is pretty light, and I would bet the revs come up so quick it doesnt accelerate the car as efficiently as it could. You can only apply as much power as you have resistance. Your car would actually probably be a good canidate for a glide. You may slow a bit in the sixty, but I would be you will make it all back and then some by the end.
Good luck
port heads and more rocker ratio to go with it?
SOFA KING WHAT?
Why is you mph so low for a 10.17 sec pass?
Fuel system issues? Converter/box issues?
What fuel system are you running?
The 950 HP is a bit small, it flows like 830 on a good day. The 950 HP is a great torquey carb with its 750 main body and 850 baseplate. A 1000 HP might get you a tenth but thats about it. You know anyone that will lend you one?
Dave
you dont have enough airflow for the cubic inches. the dart heads would flow more assuming your heads are not ported but the cncd dart 227 heads dont have near the numbers that the afr 227s have out of the box. i would have the heads and intake ported and a carb built to match the combo you will then be aat your target et for sure
LSA should be 106 to 108, 4.10's with that short tire, Strip Dominator or a Super Victor intake, the Dominator will be worth almost a tenth IF it is set up right, and the -10's are old stuff. Darts for an unported head, AFR's if you spend the extra for ported. You run good for the stuff you have.
I have close to the same cam specs as you have, I have 11.25 to 1 comp and 13/4 headers with 3'' pipes,3450lbs I run 10.05 @ 133.75 mph in the heat with a 4.10 gear on pump gas I use the dart 227 cnc heads out of the box. I also have the holley keath dorton intake with an adaptor and a 1050 pro systems carb. If it were me I would send your heads and have them ported or buy a set of the dart, brodix or afr cnc 227 heads.
Banned
The et from your current combo is not too bad actually.
But the heads / intake / carb are on the small side to feed what is essentially a big block.
To get you to your goal of .2, your going to need a better top end combo: heads / intake / carb. I also agree that ideally a narrower LSA cam would also be a benefit as well as a possible gear change that had been mentioned.
When you start head hunting, check out Curtis Bogg's web site as well. www.raceflowdevelopment.com
He does heads and intakes and likes to do them together so they work together. All work is done based on your application and his experience.
All the above being said, assuming that your chassis is sorted out to the inth degree ??
1 - 20 of 74 Posts
