1 - 16 of 16 Posts
looking to get down strip in 8-9 secs if possible...and wanting to rebuild my 400 for really high performance..and looking for ideas and help..ask any questions
not sure on weight but i have fiber glass fenders...hood..trunk lid...bumpers...all new rear end..track rod..ladder bar coilovers...15x14 wheels...31x18.5 ties...9 inch rear 4.56 spool....th400 trans brake biondo delay box....santhuff shocks and 200lb front energy springs....2 racing seats... 6al2 msd 2 step box...
An 8sec 72 Monte might require a set of JATO bottles on strapped on the roof. That's a lot of iron to get moving. Bitchin' body style though.
The Warbird
If your talking 1/4 mile with a SBC you will need to spend about $15,000 on a new block, crank, rods, pistons, heads etc... and another $2500 on a killer nitrous system and controller.
1/8th shouldnt be a problem with your current engine
The Warbird
Btw theres a good bit of difference in a 9 and 7.50 1/8th mile pass, at 3200lbs a 7.50 takes 400hp, a 9.00 takes 233hp
Discussion Starter · #9 ·
never ran down track but 412..(.60 over)..13.5.1 compression h beam rods....just got new 215cc dart pro 1 heads (had trick flow)....electric w/pump.. dart intake (on the way) 1050 dominator ...wat u think
KEVIN CAPS LOCK
I NEEDS ONE OF THEM! :p
Why do we not run the current setup and see how that does before trying to set up a new combo?
HOW MUCH DO YOU WANT OR HAVE TO SPEND.
1 - 16 of 16 Posts
