My kid brother bought a Patriot crate 383 from Summit a few years back. Project 69 Camaro build, got it going earlier this year and had fits making it idle. Had a brand new Quick Fuel 750, I got involved when he asked to borrow the carb off of my 69 Camaro 383 (600 Demon) to see if it made a difference. It did not.
The engine has now developed lifter noise (60 plus psi oil pressure) running 10-30 Castrol. My bro goes to adjust valves (intake with exhaust just open, exhaust with intake almost closed) and calls me up to say several lifters feel solid and are opening the valve rather than compress lifter. By the time I got there he had the intake off and lifters out. Sure enough, quite a few of the lifters are completely pumped up solid.
He called Howards up and was told those lifters will pump solid at 5psi and must be adjusted running??? Not sure how that will help if the lifters are not going to give at all.
Why are only some pumping up? I was able to compress the lifters with a vise by slowly pushing the oil out but feel like it will happen again the moment we reassemble. According to build sheet it has the correct seat pressure, I haven't checked geometry yet or seat pressure on head but am going to have a look today. Lift is around .560 BTW, total of about 300 miles on engine.
Any thoughts?
Any thoughts?
