We wiped out the solid roller and want to switch to a hydraulic roller.
1984 Monte Carlo
3800lb with driver.
4:10 gear. Rear tires are 28.1 diameters with 10 inch tread.
TH-350 with lowered gear set (2.75 1st)
ATI 9 inch 4000 Conveter
Motor is 496 BBC
4.310 bore X 4.25 stroke and 6.385 rod
12.3 to 1 compression
Edelbrock Super Vic intake (no port work)
1150 cfm carb
Headers are 2 inch by 30 inch primary with 3.5 collectors.
Dual 3 inch exhaust with X-pipe to the axle.
Heads: Trick Flow 340R
2.250 intake and 1.880 exhaust
122 cc combustion chambers.
Intake cfm exhaust cfm
.100 77 64
.200 160 125
.300 230 166
.400 283 202
.500 323 241
.600 350 270
.700 366 290
.800 370 301
28 inch of water with 2 inch pipe per Trick Flow
Current camshaft
Comp Cams 11-744-9 marine solid roller
Advertised 295/305
@0.050 262/272
Lift .670/.670
Center line 110
Ex in
Closes 42 atdc opens 38 btdc
Opens 83 bbdc closes 77 abdc
Thank you in advance.
1984 Monte Carlo
3800lb with driver.
Motor is 496 BBC
1150 cfm carb
.100 77 64
.200 160 125
.300 230 166
.400 283 202
.500 323 241
.600 350 270
.700 366 290
.800 370 301
Current camshaft
Advertised 295/305
@0.050 262/272
Lift .670/.670
Center line 110
Ex in
