1 - 13 of 13 Posts
I always thought a solid roller cam would make more power is this always true? I just had a new sbf 8.2 352 ci blower motor built running a ysi and 25 lbs boost and went to a larger solid roller cam and after porting the heads( old hiports) larger cam 670 lift ,it made less power.
I wanted to know where to start to find out what might be wrong?
motor is also down on boost a little but its not intercooled so I don't think this cold be the problem??
Thanks for any help
`Larger cam not always better with a blower/turbo setup.. The cam must be custom to the combo/// off the shelf cams will work but will not preform as well as a custom grind... Solid cam = higher RPM with less problems... I would say the cam is your issue
motor is down on boost - Found your problem
Larger heads, bigger cam that bleeds off boost, lots of variables in the combo.
If you lost 5lbs with the new cam/heads then you could be down 100-150hp or more in some cases.
Discussion Starter · #4 ·
I'm still using the same heads with a little porting ,could the cam not be degreed properly?
Discussion Starter · #7 ·
how much overlap? new vs. old
The new cam valve overlap is 45.4 crank deg.
lobe seperation= 112.2 cam degree
The old cam is one of those secret squirrel ones I got from Larocca years ago. I know its alot smaller. I will try to look it up...
Thanks for your help!
I have one of Jimmy Larocca,s cams in my old combo and i know he liked 115 lobe center.Are you sure with the 112 you are not blowning the boost pasted the valves? 112 is more of a NOS cam i thought? Im no ex on this but just a thought.Are the valve springs good or maybe a little weak if used? Good luck.
I'm sure the blower is putting out the same amount of air,so you can't really say loss of boost is the problem,as boost is just a measure of restriction/backpressure,and since you ported the heads,should maybe be less? I would say the cam is not as efficient.???
Discussion Starter · #11 ·
I think its the cam also.
If its a Larocca cam, its pretty good. All of my stuff is still being done and designed by him. My good friend is his best friend. PM me if you want, I will put you intouch with my buddy. He is very very good on cams.
Discussion Starter · #13 ·
OK Thanks
1 - 13 of 13 Posts
