1 - 20 of 252 Posts
home unit:
is it possible to introduce air by not cracking the lines open properly on the manifold....
I think I fucked up and now I have air in the lines, I can hear it gurgling and slushing around and the charge did not help with the cooling?...
if so, how do I bleed the air out?....is that even possible?
If you have air in it your high side pressure would be extremely high. What type of pressure are you running.
Yes it is possible to introduce fresh air when charging... When I add refrigerant to a system I will hook up my gauges, hook up to my bottle but leave bottle loose, open up my low side of manifold and and purge refrigerant to bottle, just for a couple seconds.... When purged enough tighten up bottle connection clost low side, zero out the scale and add refrigerant. Don't kno if that helps but when I add refrigerant that is how I do it.. Also usually if there is air or noncondesibles in refrigerant your high pressure will flicker..
How much charge did you add? Did you add to a "low" system? If so, then there is a leak somewhere (leak = air getting into the lines all the time). It's not uncommon to hear the refrigerant gurgling in the lines. Did you check superheat/ subcooling? If so, what readings are you getting? What is your supply/ return temperature difference? Not trying to be a smartass, but these are things I would need to know before I could say where the problem may lie.
x2
yoiu are probably hearing gas in the liquid line.On a undercharged unit you wll have gas and liquid,you should have a solid column of liquid.Without the pressures its hard to tell.Watch your gauges and the non-condenibles will spike the head pressures as it travels thru the compressor.
Discussion Starter #7
I dont know enough to answer any off those questions....dude came over with a bottle of 22, and some gauges. after all was side and done I started thinking about having not purged the lines. and here we are...
Discussion Starter #11
that gauge reading is rock steady...
What is the indoor temp... With r-22 suction pressure will be +-5 psi of indoor temp... So if 72 degrees suction pressure ( low pressure) will be 67-77. As a rule of thumb. What is high pressure reading.
If it is 76 degrees inside and there is no moisture forming on suction line I would add more....just me, not having all the info sounds like it needs more refrigerant..
1 - 20 of 252 Posts
