Whats your take on the Kolene steels Hutch ?
Any particular reason you don't like them in the 400's? I haven't seen any issues with them holding up, but then again, my customers probably aren't leaning on them as hard as others are. My quickest is only running high 8'sI know what Hutch will say,but i've also used them with good luck, particularly in a Glide high and rev.
Not so keen on using them in TH400's. I'd rather use BW smooth and stock flat steels in that trans.
No reason apart from the fact that in 99.9% of TH400's i do they work really well. No use rocking the boat..Any particular reason you don't like them in the 400's? I haven't seen any issues with them holding up, but then again, my customers probably aren't leaning on them as hard as others are. My quickest is only running high 8's
Frank
