Did GM make any valves for 1-2 shift from the factory that would hold low gear? I have a early model valvebody that you can't bolt the filter to. The valve is made the same diameter and has two oil grooves cut in it. The valvebody has the hole that you normally plug in it though.
Thanks ahead.
Thanks ahead.
