1 - 5 of 5 Posts
What is the minimum height you need between the top or a 2100cfm terminator and the hood?
Thanks Don
That is pretty close. I'm not sure what to predict will happen. I'm positive that if it slows down it will not be because of the turbulence that would adversly effect a carb but will bu because the air is being choked off. Like someone said on the other board, make sure your hood doesn't flex down at race speeds
1 - 5 of 5 Posts
