it's for a 440 running a 14-71 on alcohol, 12.5 to1 compression, and the only other thing i see is i would be running 1.5 rocker ratio
grind# r2624-2583-14
intake rocker ratio 1.7
exhaust ratio 1.7
lash @23
intake & Exhaust
LOBE SEPERATION= 114 cam degree
valve overlap=34.2 crank degree
Intake
valve open= 22.4 btdc
Centerline 109.9 atdc
valve close= 62.3 abdc
Duration 264.7 Crank degree
lobe lift= .42937 in
valve lift= .730
lobe area= 38.24 in *deg
Exhaust
Valve open= 67.8 bbdc
Centerline 117.9 btdc
valve close= 11.9 atdc
duration 259.6
lobe lift= .4139 in
valve lift .704
lobe area 35.92 in *degree
exhaust ratio 1.7
lash @23
intake & Exhaust
Intake
valve lift= .730
Exhaust
duration 259.6
lobe lift= .4139 in
valve lift .704
