Nope these are legit numbers with a legit correction factor.You may want to download a better run, if this is a show car these numbers will not cut it
Nope its a 770 quick fuel carb with a stupid cam and only 325ciis that a 350 with a 30/30 cam and a 750 double humper carb and a set of fuelie heads ?
My guess would be about 9800 rpms if the springs will take it!Going back tomorrow to find the hp peak.
I have seen these make power through 10200 rpmMy guess would be about 9800 rpms if the springs will take it!
I dont know it ill push it past 7400My guess would be about 9800 rpms if the springs will take it!
This was with a quick fuel 770 with all those fancy adjustments available but it is not my carb so we couldn't play with it.It looks good but the way the BSFC ratchets up and down suggests it may have a little too much main or emulsion air bleed. The BSFC should progressively change from higher below the torque peak to lowest at the torque peak, then progressively back toward higher numbers above the torque peak, and the step changes should be similar values relative to each other. The numbers should not go up-down-up-down-up like they are. When they are plotted on a graph they should be a smooth bowl shape, not a sawtooth. Though it is likely the carb, if the carb is not over air bled, erratic BSFC can be from a mismatch of intake and exhaust tuning and valve timing, the three factors not being ideal for each other. With an unlimited budget so you could wear out a dyno you might find a different set of headers, or a different intake runner length, or intake type, or yada-yada, would fix it up and make more power in the bargain, but you have a nice flat torque curve now ….... so...it should be fun to drive.
Its got a single "bar" spacer on it now but hes not a fan....A cross bar plate will fix those numbers right up!
Eeak.... 73ish idk?Put me down for peak at 7600.![]()
Da Fuq? :shock: What happened at 5800rpm? :smt119
Lol. You should have seen ours. I looked like a pulse monitor. Cars so loud it didn't no what it was supposed to do.
