1 - 3 of 3 Posts
hi all,
as the title says im trying to use the v300sd to runt he low oil pressure light ive ordered a 230-vm-4digout ive read somewhere thats what i need ?
anyone have any input on this ive ordered one from summit so it on its way.
rpk-230vm4digout
cheers Hayden
Australia
hi all,
rpk-230vm4digout
cheers Hayden
Australia
when you get the digout you will see in the instructions on how to program it to activate based on oil pressure below some number (you choose). Of course you must have the RP oil press kit. Also, you must use a relay or low amp LED light.
hi Greg,
yes we currently have the rp oil pressure kit so sounds like it should be all good then.
cheers Hayden
Australia
1 - 3 of 3 Posts
