1 - 2 of 2 Posts
HERE IS A LITTLE BACKGROUND ON MY SETUP IT IS A STOCK STYLE SUSPENSION A-BODY I HAVE SOUTHSIDE BARS AND E-BROCK ADJUSTABLE UPPERS SET TO STOCK LENGTH, AIRBAGS IN BOTH SPRINGS LT=12PSI RT=10 PSI SUMMIT DRAG SHOCKS SET TO STIFF MT ET STREET'S @14PSI UP FRONT I HAVE MOROSO TRICK SPRING'S 90/10 SHOCKS NO SWAY BAR AND COMP ENGINEERING LIMITER'S NOW THE PROBLEM IS OFF THE LINE I AM LIFTING THE LEFT FRONT AND WHEN IT COME'S DOWN I CAN SEE ON VIDEO THE REAR OF THE BODY SEEMS TO BOUNCE AND WITH THE BOUNCE I AM GETTING SOME TIRE SPIN ANY SUGGESTIONS ARE APRECIATED IF I NEED TO TRY TO EXPLAIN FURTHER LET ME KNOW
sounds like you need to slow down the rebound in the back,i think strange offers a bolt-on dbl. adjustable shock for for your car.you may also want to try an adjustable front .90/10 don't work that well when you are making good power.
1 - 2 of 2 Posts
