1 - 2 of 2 Posts
I need to swap to an electric fuel pump for the carbed 5.3 swap I'm planning. I want ideas on how to convert the fuel system to a low pressure efi pump without dumping the tank as I want it to look stock from behind.
Is there any low pressure intank pumps? Can I use a Holey blue pump and siphon out of the tank?
Any thoughts or pics would be appreciated.
Premium Member
Most electric vein pumps on the market need to be gravity feed to survive. However I believe there are some out there that do not need to be gravity feed. You could also opt for an "in tank" pump.
1 - 2 of 2 Posts
