1 - 15 of 15 Posts
Car has been 10.16 @ 132 in the 1/4 and 6.44 @ 108 in the 1/8
Here are the specs of my car.
69 Nova - 3200#s with driver.
434 sbc 11.3 compression 93 octane on motor race gas on nitrous
Afr 235 heads
Super Victor intake 2925 ported by cfm (Mike Stark)
Prosystems 1000 hp that flows 1022 cfm
cam specs are 264-272 678 - 654 109 lobe sep
1 7/8 headers 3.5 inch exhaust with dynomax bullet mufflers
Full msd ignition digital 6 box and probillet distributor
Autofab tubular upper and lower control arms
Qa1 coilovers in the front
Caltracs -split mono leafs-Rancho shocks
28 x 10 slicks Hoosiers
12 bolt- spool -33 spline axels- 4.56 gears ( Less gear if needed )
turbo 400 trans- 4700 stall on motor -transbrake ( Nitrous converter from PTC 10 inch )
10 point chromolly cage subframe connectors and solid body mounts.
Also what would u do a plate or a fogger?
Car came through the traps at around 6800 with the 4.56 on motor.
What do you think it will run and at what mph my max nitrous would be a 350 shot.
"Darkness"
I'd say a 4.10 gear, Direct port with a 300hp tune, And a different cam will get you well into the 8s.
You didn't mention the piston/ch setup.Aren't those 434's tight on ch?8's seems doable.
Banned
300hp hit with a 30" tire, no problem. If you want well into the 8's, different cam/gear/convertor. My 10.0 car with a 250hp shot goes high 8's, 154.
Discussion Starter · #7 ·
My 434 has a 1 inch compression height. 6 inch rod motor. I see most recommend a fogger but u dont think a plate system will get the job done. I see some people going crazy fast with a plate.
Discussion Starter · #10 · (Edited)
I really dont know cause i wasnt actually looking at the tach thru the traps. My friend who was also driving said he seen the tach at 6800. Wat do u think i came in thru at 4.56 gears and 4500 stall 28 x 10 tire 3300 #s with driver. Track was atco raceway dont know the elevation i think it is sea level.. Thanks
You should be up over 7500 rpm with that combination. Accounting for 5% or more converter slippage. Sounds like you have a 4.10 gear in the car.
What does the car 60 ?
Definitely agree... Some simple math tells you that at 6800rpm, you could only do 124mph AT BEST (no slippage). 7500 with 3% slippage would be 132.8...
Something is funked up here.
I'm not sure about how easy it is but on my 434 AMC it took 400 hp nitrous to get into the 8's
3.89 gear 7600 rpm at 154 mph data loged
28 tall ET street
cal-tracs 3300 pds.
8.95 at 154
engine made 741 hp N/A
it also took a while to get the chassi and engine tuned to run 8's
it was not just a matter of slapping on a plate and running 8's.
Good luck to you but I didn't think it was easy.
I see a broken block in the near future......
I hit my 383ci with a 250hp and it goes from [email protected] to [email protected] with the digiset coming on kinda late....Dont see why you can go in the high 8's with a good nitrous tune-up...
??? Why do you see a broken block just asking I have a similar combo w/AFR 227's, 3080lbs, 73 F body, glide, 4.10's, a diffusuer looking for 8.50's, best so far [email protected] 129 in the 1/8th.
1 - 15 of 15 Posts
