21 - 24 of 24 Posts
With a 4.7” bore and 4.375” stroke you could get it up to 607” and not have to turn it to the moon.
Rod ratio would not be to good.
New drce 2 deck is 9.525. No way at 9.0
Chevrolet Performance DRCE 2 engine blocksfeature a relocated camshaft that has been raised to 5.750 in. The deck height is 9.525 in. and can be reduced to approximately 9.000 in., the distributor hole has been moved rearward on the block, and the overall weight has been reduced by approximately 11 lbs.
21 - 24 of 24 Posts
