1 - 10 of 10 Posts
Just curious.........
How much HP does it take to make 3780 lbs
run 130 mph in the 1/8 mile ?
T/S 368E
A LOT
After some good tunning advice this weekend I was able to make back to back 130 + mph passes. I have been 129 before in great weather but never 130 and certianly not in the heat. One kit on a conventional headed BBC in an all steel, except the hood, full interiored, stock suspention 69 Camaro. :smt040
Thats a new best for me so I was just interested in how much power I might be making.
Now this is jsut what I have seen from a couple of other cars. But I have seen a couple of other cars barely break 130mph, they were lighter than your car and both of them made right at or just over 1000 rwhp through a glide
EFI/N2O JUNKIE
Ha, a Butt Load!!!!
3800lbs going 130mph in the 1/8th needs a lof of power!
I've been a whopping 116mph in the 1/8th with a small shot that put 625hp to the tires on a chassis dyno.
Pull 3 plug wires and I'll run ya heads-up! :)
T/S 368E
Nice outing. I know that thing is making some power. At 3200 lbs & 1050 HP, I was running 127 mph in the old car.
Discussion Starter · #10 ·
Still going at it
E/T was not up to the MPH because I haven't let it eat out of the
hole. I am delaying the hit just a bit and the 60ft are off just
about .1 to .15
The tune is clean and now I will start to work that delay down some.
If I turn the n2o on earlier in the run it should even run a touch more mph .......you think ?
You can't .........
No I can't just hit this much weight with that much
power out of the hole.......it breaks shit.:rolleyes:
I'll be glad just to get any sub 5.60's again. I'd jump up and down for 5 .4's :smt031 :smt082 :supz:
1 - 10 of 10 Posts
