1 - 10 of 10 Posts
I have thrown my old 383 back together. But i took off my 867 pont heads and built it with a set of 230 patriot heads cc ported that flow 296 on intake 236 on ext. My pont heads flowed 368 intake an 294 ext....Anyone know how much hp I will lose....Hope my 408 will back together for next year with 15 deg heads ..But for now we had these parts laying around so we can atleast play this is what we put together...
Its a 13.5 comp, it has a 660 lift roller. 350 block an a 3.750 crank made by scat..vic jr intake....And we will try to match the intake to the heads. But the 867 heads are rasied runner and a great head....I was wonder how much the less flow number will make on the power....
Discussion Starter · #4 ·
How much power do you guys think it will make.....383 ci 13.5 comp 660 intake 645 ext 328 an 328 . 107 centerline. patriot 225 cc runner heads, 208 intake 160 ext val...the heads are cc ported flow 296 intake 236 ext...ported vic jr intake .1.5 harland sharp roller rockers.7/16 studs...950 holly hp carb 2 in super sucker....Its going in a 2668 lb 1969 25.5 chassie nova......Its made up of parts we had laying around.....
Butch
Don't know much about the 23 degree heads you have but I would guess 550hp to 600hp, could be more but again I'm not sure with those Patriot heads
Discussion Starter · #7 ·
We took the car out tonight for some test an tune....It went 6.90 in the 1/8 ....But we have a real bad handling problem to fix be for next weeks race.....It leaves straight but it is all over the track....We think it has a toe out problem..going to align and see....But the heads work pretty good for what I paid for them Heads Intake an roller rocker was 1500.00 new....And my 867 pont heads the car only ran 4 tenths faster....But there is stilll alot left in this little motor.....
There must have been a problem with the other combo also. If it didn't run, but 6.50 in a 2700 lb car, then it wasn't making but about 500 horsepower. I would think you would be able to run 6.50 or faster with the Patriot heads.
Discussion Starter · #9 ·
Its the same cam , pistons an crank form my old 383..And I think there is alot left in the car . I couldn,t run it out the back door it was all over the place....But these was the first time out with the since we redid the car still working the bugs out.....Will have a big motor back for next year just threw this together for fun....
Discussion Starter · #10 ·
We ran the race at Us 43 today...The car ran 6.70 at 102.93 mph...Not bad for some cheap heads and old parts we had laying around....
1 - 10 of 10 Posts
