Im thinking of upgrading my motor later in. How much power would you consider safe with a sbc 400? Im thinking about possible adding some boost to it.
The block on a 650-700 Hp N/A 400 motor changing to a Dart will make 30 HP
Boosting it, save your money get a block
x3. I found out the hard way
X4The block on a 650-700 Hp N/A 400 motor changing to a Dart will make 30 HP
Yea, I know, hoping to make it thru this year.Stock 400 blocks are garbage, been there done that.
Lightners, it's only a matter of time before you run over the crank...
