1 - 16 of 16 Posts
i went last night and went from 139 to 155 mph on a 93-102 bigshot plate. on a 55-55 i went from 139 to 147.
Vendor
I pick up on the average about 15 mph with a 26-30 jet in the fogger from the motor mph. 138 to about 153.
Premium Member
That's a tricky question it depend's on what the engine was built for NA or juice a nitrous engine will pick up way more, I ran a cheater at 250 and went from [email protected] 116 to 10.00 @ 135 with a 355 then went to a 383 with a big shot at 350 [email protected] 123 to 9.40 @ 145 and a 400 with a big shot at 350 and went [email protected] 135 to [email protected] 154, I would think a 15 mph jump and 1 to 1.5 in ET is about right for a 275 shot
I went from 11.83 at 113 on motor then hit it with a 100 shot an hour later at the track and went 10.83 at 123, so...... 1 full second and 10 mph, then got booted for no cage.
Cage and lots more nitrous coming this winter.
Administrator
It depends if the motor will accept 275 HP or not.. Your best bet is to step up in 50 HP increments to 200 HP then in 25 HP increments..
On a 250 shot I went from 136 to 152 MPH.. The MPH is depended on more than just the amount of nitrous you put to is.. IE: Rear gear, converter, cam, chassis.. etc etc..
Monty Mikho said:
YDLUZ, its either the video or something sounds kinda messed up about 1-2 seconds into the run. Also looks like the shift light is hanging in there for a bit at the end. Kind hard to tell.. Is that a playback tach? Is so what happened for the motor to break up at the start?
Hey Monte, I moved my question to its own thread so not to hi jack this one. Shift light is 6,800. The noise you here is shitty video quality I'm pretty sure. See the new thread.
My Nova when it had the GMPP 502 with a solid roller, mild head work and a Big Shot plate would run N/A about 11.60 at 118. With the 275 shot it would run around 9.85 134 range..........best was 9.76 136 range with cool fall conditions.
1 - 16 of 16 Posts
