Nope.I have 520 rwhp at 3300 lbs and as soon as the air gets cool, I should be able to slip into the high 9's. Right now.... 1.38 60 ft 6.46 1/8th = 10.20's in 3000 ft DA. Texas summer bites. This is a fairly mild street/strip bracket car.
If you get your car 60 footing, it doesn't take a gob of HP to dip into single digits.
A single 465 won't cut it unless you run it right on the edge.Ok so it sounds like it's safe to assume a minimum of 625-650rwhp (depending on 60ft).
I'm trying to decide on whether the Walboro 465 pump (on pump gas) will provide enought fuel to support that. I'd like to be in the high 600's or right at 700rwhp if it would push enough fuel.
-Mark
752!... :-damnitAt least 750hp![]()
-Mark
Yup everything comes into play . Gears ,converter , trans , weight , Da,420rwhp with a 250 shot was good for 9 teens at 148 at 3200
And 5 years of figuring all thatt shit out!Yup everything comes into play . Gears ,converter , trans , weight , Da,![]()
