Powerglide with no cooling, 10" NC Converter and a stock pan. How much fluid if I drop the pan and change the gasket? I need to know so I can mark my dipstick. Thanks in advance.
Take off the pan and mark the full level 1/8" above the oil pan rail and you will be very close. I would like to see you install a deep pan if you can.
Hutch
Would that be close enough to call it good
Is this mark when the car is running or cold ??Take off the pan and mark the full level 1/8" above the oil pan rail and you will be very close. I would like to see you install a deep pan if you can.
Hutch
