So 8 single nozzles are good for 200-250hp?Depending on the nozzles they could be good for 200-250 hp.
Did you mean 8 of these "single" nozzles per stage?So 8 single nozzles are good for 200-250hp?
8 of these fogger nozzlesDid you mean 8 of these "single" nozzles per stage?
http://www.holley.com/13500NOS.asp
Not a single (as in 1) per stage.
The choice of nozzles and solenoids can dictate what it can pass. But it can be done typically thru a good annular style nozzle is your best bet.. SJI'm trying to find out how much nitrous a single fogger nozzle can flow? We have a dry kit (EFI) and we use single fogger nozzles to run 2 kits up to 500hp. Any problems with this?
We have the fuel side running our first stage (26 jet) and the nitrous side running our second stage (28 jet). Just want to make sure these can flow that much. Thanks
