1 - 6 of 6 Posts
I have a 1969 Chevelle with a 454 that I feel should be faster or at least has the potential to be faster. My specific question is in regards to the current camshaft/rocker ratio. I'm running a Comp 288A-R10 solid roller with Crower 1.6 roller rockers. Specs for the cam are 246/246 @ .050 with .3666/.3666 lift and a 110LSA. With my 1.6 rockers that's only a .586 lift.
The engine is a 4.250 bore/4.000 cast crank, 12:1, Edelbrock 6055 heads with mild cleanup on exhaust by me (picked up .20 and 1 MPH), Comp valve spring 929-16 as recommended with the cam, Victor Jr and an 850 Holley.
The car weighs 3530lbs with me in it, has TCI TH400 w/brake, B&M 3000 Holeshot, 3.73 and 28x10.5 MT slicks. Best run is below and was at Fontana Dragstrip in CA.
60ft - 1.545
1/8 - 6.979 @ 98.850
1/4 - 10.993 @ 121.630
So given the rest of this combo would I benefit from upping the rocker ratio to a 1.7 or 1.8 or from a different cam with more lift and duration? What are your thoughts?
Sounds like a pretty fair combo for a street/strip car with that small a cam, but I think a bigger cam will pick it up some. My pick would be a custom roller from Bullet Cams
60ft - 1.545
Looks like it runs pretty good for the combo and weight...What is your compression ratio and what type of fuel are you willing to run?
I'm sure there is a better torque converter out there also.
It has 12:1 compression and I run it on VP110. I do have a new Freakshow converter as well but I'm still putting the trans together so I haven't run it yet. Given the rectangular port heads that are supposed to flow well up to .700 lift do you guys think switching from the 1.6 rockers to a 1.7 or 1.8 would be worth anything?
I would go in this order:
  1. pick a target RPM to cross the finish line at
  2. do your heads, intake, carb and bottom end support that RPM?
  3. pick a cam and springs that support the target RPM
  4. pick a tire size
  5. pick a gear size
  6. pick a converter that will be between 1200-1500 RPM below your shift point
  7. Run the crap out of it!
Good luck,
Cole
1 - 6 of 6 Posts
