1 - 20 of 62 Posts
REBUILDING
Id like to take a informal poll, so that guys can have a reference/ starting point for what air pressure to fill their slicks with.
Please provide as much info as necessary.
How much air do you run in your Slicks?
What brand slicks?
How much does your car weigh?
What type of rear suspension do you have?
What size rear tire?
60 foot E.T. and car type?
My 64 Chevelle has a 4 link and so far in limited testing, I have had a 1.33 60' best time, at 3460lbs w/driver and 7.0lbs of air in the M/T 13.5x31x15 slicks. Ive tried upwards of 8lbs of air. The 60' time slowed down.
1. 6 - 1/4 lbs air pressure
2. Hoosier slicks
3. 2658 lbs with driver
4. 4 link
5. 33 x 16 x 15 diameter.
6. 1.08 - 60 ft
7. David Monday Race Cars 68 Camaro ( Tim McAmis carbon fiber
body)
How much air do you run in your Slicks? 7-7 and a half
What brand slicks? Goodyear #2078
How much does your car weigh? 2550
What type of rear suspension do you have? 4 link
What size rear tire? 33/15/15 stiff wall
60 foot E.T. and car type? 1.12-1.27, we have 2 engine combo's we run with this tire. Chrome moly tube chassis
hoosier qtp 26x9.5x15 10.25 psi
How much air do you run in your Slicks? 17-17.5 lbs
What brand slicks? M/T
How much does your car weigh? 3700
What type of rear suspension do you have? Stock
What size rear tire? 28x10.5 Stiff
60 foot E.T. and car type? 1.50 bracket car
Loaded question. I have posted this before. Your gauge may read 5 lbs, mine on the same tire reads 10 lbs. Use it as a reference point. Run as much air in your tires w/o spinning. Then set them to that point on YOUR gauge only. Just like EGT. All of them read different on same car. Use as reference point, that your turning back to same point always. Same with timing lights, delay boxes, transbrakes, etc. They all are not exact!
How much air do you run in your Slicks? 15.5 - 16 lbs
What brand slicks? Hoosier QTP
How much does your car weigh? 3490
What type of rear suspension do you have? stock leaf springs and slapper bars
What size rear tire? 29 X 14.5
60 foot E.T. and car type? 1.40 Professional Test & Tuner lol
How much air do you run in your Slicks? --- 6PSI
What brand slicks? --- Hoosiers
How much does your car weigh? --- 2450 w/driver
What type of rear suspension do you have? --- 4 link
What size rear tire? --- 15-33
60 foot E.T. and car type? ---- 1.14 / 1.18 71 Olds Cutlass
How much air do you run in your Slicks? 13.5
How much does your car weigh? 3000 lbs
What type of rear suspension do you have? Leaf Spring
What size rear tire? 28 x 10.50 stiff
60 foot E.T. and car type? 1.28 67 Camaro, small block, nitrous
Car 60's better on 275's, as well as being quicker and faster.
PROUD AMERICAN WORKER!
There is I formula that you divide the weight by. Gets you a great starting point for a baseline. I remeber that was amazingly close. It cannot find the factor.
Steven, how new are those tires?
13psi
Mickey Thompson
3153lbs w/driver
Stock type w/relocated uppers, lowers parallel to ground with front rod end 1/4" higher than rear
26x10 Stiff sidewall slick
Mid 1.5 sixty, Mustang Gt, stick car, leaving at 6500rpm
1 - 20 of 62 Posts
