1 - 20 of 311 Posts
Just wondering what you guys running 8's in street/strip cars are running for combos and horsepower ranges. Looking for stock suspension 3000+lb cars that don't have 100K into there builds. Lets see some pics too. :smt077
This is the car in my sig.
Not quite 8's yet, but we are hoping to run that number this month. Car is 4,000 lbs with driver. Right at 1,000 RWHP on E85 on the [email protected] pass. That was with a 1.68 60' on 19" Drag Radials. Going to put some 15's on it and put it in the 8's as it sits. Then we have a new engine going in with a stronger block and some bigger turbos. These turbos are 60's. Hoping to go 160+ with these before the larger turbos go on.
Could only imagine if the car as 3,400 lbs or so.
Nice Transam, what was your engine combo and why did you sell it?
Bad azz 5.0 too! Is that a stock 5.0 shortblock?
build them everyday.....no where near $100,000 for a 8 sec turbo car.....hell i got 7 sec turbo street car....no where close to $100,000 if you actually do it yourself.....:cool: if you dont do it yourself...and pay everyone else to do....you could have a 100k in a 12 second ride!!!:smt082
383 billet splayed 4 bolt mains callies crank oliver billet rods je pistons afr227 heads jesel shaft mounts 248/248 sr cam. Victor jr and sheetmetal elbow with monoblade.
Got burnt out on it was worried about the stock non filled block at those levels. Finishing up a dart 427 101mm fox now
Mines not done yet, I think it will be a high 8 sec street car with the stock short block with more cam. I've got around $40,000 in mine so far and need about another $4000 to finish.
Mine doesn't see a whole lot of street time at this point, but I'm hoping to change that by getting rid of the rear mount radiator and going to split radiators in my lower valance to make it more driveable. Stock block 388 w/ half fill, dart pro1 215's, ultradyne custom solid roller camshaft, unported super victor intake, and a c&s 900 ethanol blowthru. [email protected] with a 1.46 60 foot on 28x10.5's @ 3200 lbs.
Drag Week Survivor
Blothru Bullsh!t
Theres alot of them . lol .... Mines not in the 8's either but 9.37 in a 4450lbs in a pick-up truck , stock leaf spring , cal-tracs , 1000hp with standard cover S480 1.10/87 turbo on a 383 sbc . 750 blow-thu carb . 13psi on pump gas for street driving ........22psi on C16 at the track . 7531 ignition .
Street driven and still works a little .
http://www.youtube.com/watch?v=iC6kSl8PvkA&feature=my_favorites&list=FLia1tZwx-4Ksj0lXSBizPvA
Sweet, nice truck!!
^^^^^^^^^NICE^^^^^^^^ and FORD powered!!!
1 - 20 of 311 Posts
