1 - 3 of 3 Posts
HI i want to change back to 2 stage shift kit in my th400 ,it is full manual valve transgo kit,how hard to change back?
Anyone every seen car slow down few mph when changing to full manual valve with no other changes to car?
Any link out there showing how to convert back to shift kit
thanks
victtor
new zealand
Pull the governor out and take off the big spring that holds the gov valve open.
There may have been a mod to the modulator spool valve you may have to undo as well install the vacuum modulator valve along with the governor alteration mentioned above.
Hutch
1 - 3 of 3 Posts
