What heads? Blow thru or EFI?There will be many that have gone way faster than me, but I have gone 6.11 in the 1/8 only turning the blower 40,000 RPMs. It has got a lot left in it I'm sure. Details in sig.
AFR 195 heads, Comp hydraulic roller 242/248, .540/,562 with 110 LSA. It is a blow thru 750 carb built by The Carb Shop. Shift at 6200.What heads? Blow thru or EFI?
Those are some really impressive #'s, I assume this is also a street car?We've been [email protected] in a 3350lb Corvette Z06 in full street trim (nothing is removed from the car and has a 6 point roll bar) with a STOCK (never had the valve covers off of it) LS7 (427ci).
Is that your Nova on pg 34-36 Super Chevy Dec 11?10.55 at 128, 12lbs of boost
406sbc 9.5-1
blow-thru csu carb
A/A intercooler
Yes it is......Is that your Nova on pg 34-36 Super Chevy Dec 11?
Nice write up, looks great, very clean under hood!
We have a similar engine combo both from S-o-M, ck your valve train. Then turn up the boost and go 9's easy.
To the OP Sorry for the high jack.
---Bill.
How fast have you been with a D1SC and a small block?
What combo?
What weight?
