1 - 20 of 31 Posts
i picked up a steel headed bbc 468 ci
3964291 casting numbers on the heads
361959 block number
3967416 crankshaft
has ross pistons with some big domes
has solid roller camshaft and solid roller lifters
oliver rods
crane roller rockers and stud girdles
high rise intake with dominator flange
seems to be a ton of port work on the heads and intake
what size carb should i start with
and has anybody ever been fast with this setup
its going in an ex 10.5 car should check in around 2600 lbs
my car with stock 781s ran 11.0s at 127mph
9s at 135 138 on a small shot threw mufflers on dots driving to the track
Went 8.30's with a iron headed 502 crate motor with SRP 13:1 pistons, decent cam, untouched heads, Alcohol Dominator in an old crappy dragster.;)
5.57 in the 1/8th. Merlin iron heads, steel crank, 275 shot. On 275dr @ 3250 G-body El camino
We had a iron headed 468 with a train load of nitrous going 5.0-5.06 for a long time in a 3200lbs backhalf 67 camaro.
Grizzly
i dont see why you cany get in the 4s in the 8th with what you have posted...steel heads will out run aluminum they just wont cool off and disipate heat as quik
yep its a BBC !!!!!
What exactly is your combo? I've always wanted a BBC in a fox.
496ci Iron 990 heads, edelbrock 2927 intake, scat crank and rods, diamond pistons (13:8:1). SV1 carb, IS fogger, nos launcher progressive, JW bell turbo 400 if you want more specifics shoot me a PM.
Beer me!!
That's alright, I get the gist of it. That's pretty stout for 990 heads, nice work!
I like this, any vids?
I want them valve covers! You mind pming me what cams in it? Ive got almost the same setup but only a 477. Hopefully itllrun mid 5s at 3600lbs race weight!
1 - 20 of 31 Posts
