1 - 13 of 13 Posts
SOFA KING WHAT?
Mid frame, small block, around 3100 lbs with good cylinder heads and suspension?
Hey John,
Here is a note from quick79 on here...
"with the 75mm version s400 from majestic went 5.90's with that turbo at 16lbs of boost"...
He also said at 20lbs with the 80mm (S480) version he went 5.60's.
I think his car weighs about 3450 though and he was running a 406sbc stock block.
Ben
SOFA KING WHAT?
Thanks Ben, I guess nobody else runs a 76 mm turbo on a SB?
THE BBK
As said go to Turbomustangs.com and look up project Pumpkin Head. Sbf, air to air with S480 75mm. going 5.40s on radials and stock suspension
SOFA KING WHAT?
Discussion Starter · #10 ·
Actually they are all great replys, thanks guys. I've been out of the turbo stuff for awhile are these small or mid frame turbos?
the 76 is a mid frame turbo,here are a couple of pics compared to a 106
1 - 13 of 13 Posts
