What do you have rearend wise, and what do you use for traction aides?[email protected] mph stock block 383, on 275's
Well the obviously work! I have a 9in with the same gear going in. I have been told my slid-a-links will need to be modified to fit around the 3in tube housing. Thats why i asked, thanks.I have a Ford 9" with 3:89 gears. It has a set of home made slapper bars on it
engine specs? gears, convertor, trans? please. i just built a 91 with a 331" and 125 plateMine is in '85 Camaro that weighs 3100ish lbs last time I checked without me in it. Stock suspension, 275 DR's. Best [email protected]
