1 - 3 of 3 Posts
· Registered
Clearance between inside fender well and frame is 16". Max Dia. is 32". Whats the best tire for maximum hook that will fit within these perameters? Also what rim size is required. I'm currently using a 10x15 rim. Will this rim work with your recomendation?
· Registered
Ray...I dont think you need anymore than the 3062 tire you have been using..!!!! just get a set of 12" wheels with the correct backspace and it will make the tire wider in the "section" area...close to 13.5-14"...that leaves an inch or so on each side.
1 - 3 of 3 Posts
