1 - 20 of 36 Posts
Planning on running with the new motor this weekend. I am only gonna be running one 200 shot the full length of the track.
Car weighs 2650 with me in it, 180 low gear glide, 4.30 gear, 632 bbc 12 degree motor, .800 lift cam, single carb.
Motor made 1070 horse with no nitrous.
8.30
Hope it goes a little quicker than that. I gotta run 7.99 to qualify.
T/S 368E
Considering that's a 7 sec on nuts combination,
here's hoping for 7.40's if you get dialed in quick enough to qualify.
Why such a small cam & single carb??
top sportsman? it will be close may be a little short
Yeah T/S... I used to run a blown motor and ran 7.20's it was around 1400 horse at the time. I have 2 more stages but don't really want to dive into those until I get all the bugs worked out.
The motor has gone 4.41 to the eigth in a door car and 4.14 in a 2000 pound dragster but that was on three 200 shots
Discussion Starter · #7 ·
The cam and carb were limited by the class it used to run..
I would love a sheetmetal intake and dual carbs with a bigger cam, but I am limited financially right now... Lol
T/S 368E
Got it. At 2600 lbs, with an iron headed 477" on nuts, out of my crew chiefs street/strip car,
I ran 8.30's with the nitrous gear and crossing the line under 7000 rpm.
You should qualify easy, like I said, if you get it dialed in quick enough.
Good luck.
Discussion Starter · #9 ·
Thanks! I will definately update everyone after the race. Maybe if I get time afterwards I will light off another stage. I want to take it a little slow since its my first nitrous combo. I have always run supercharged in the past
Discussion Starter · #11 ·
Awesome. Which car are u guys bringing9
the trans am....we need to get it dialed in before NJ. Hoping for 6.40's i HOPE. We have the power it's the clutch we need to work with. We set the clutch with 105 grams and will let it fly...will be either smoke or will be gone.....lol;)
Discussion Starter · #13 ·
Awesome... I cant wait to see it run!!!
"Darkness"
Allot depends on how correct your 200hp tune is. ;)
T/S 368E
You guys are nuts, even with a baby cam & single dom, he's got the good heads.
Plus a 200 shot, barely in the 7's?? Come on!!
Hi Louis,
1 - 20 of 36 Posts
