21 - 23 of 23 Posts
Same here. M/T has very few sizes available now days! I used to run ET Streets years ago, but now have to run QTP 31/13.50's.
I think Brian’s running a bit bigger tire. I’m running the bigger MT they make. 32x14.25. They do work well. Wanted wider but they don’t make em. Have to bump up to 33 in Hoosier to go wider.
edit - I reread Brian’s post. It wasn’t bigger, just didn’t have the size 🤷🏻‍♂️
I went from a 28/13.5 ET street to a 325/50 radial, it is much nicer driving with the radial but it did slow down a tenth, I had to lower the rpm on the hit for the radials
For info,street traction was going away with the QTPs after about 6-8 hard pulls. They were "feathered" bad,rotated side to side and the traction is back.
21 - 23 of 23 Posts
