1 - 5 of 5 Posts
TEAM CARB
I have 2 minus holding front corners of my hinged FG hood. I'm using the stock latch currently. If I use the minis only, will I need to put springs on them?
#Tittipicsmatter !
I always cut a small rubber hose and slide over the pin. That way when you put the hood on you can mash down the hose and the hood don't vibrate or bounce.
TEAM CARB
Good idea. I was mostly wondering about "ejecting". Since if I go this route Id remove my factory spring.
1 - 5 of 5 Posts
