1 - 4 of 4 Posts
I have a friend interested in putting EFI on his street/strip car. It's probably only a 500hp motor and he doesn't want to drill the intake so I figured the Terminator would be a good setup. My question is, are you limited to the handheld programmer or can you use a laptop to tune like the HP systems? Also, do you have the ability to have separate inputs/outputs like the HP (he is adamant about using knock sensors)?
Thanks,
Chris
Holley only has two current ECUs that I know of......Dominator, and "everything else." This means you can plug a laptop into it and go to work. Denny over at the Holley forums is really helpful. You can download the (laptop) software for free from them if you need it.
1 - 4 of 4 Posts
