1 - 20 of 34 Posts
What all do I need to run Holley's coils on each cylinder with the Holley Dominator EFI?
Which main harness (part number) do you have?
don't have harness yet or ecu yet jut wanted to know what I needed to do it going to purchase soon wanted to upgrade ignition for alcohol and boost.
There was a post not too long ago where someone listed all the harnesses you need to run Dominator and COP .
Anyone have the link ? I could use that again .
Wasnt too hard to find .....lol
You need:
54-114 Dominator ECU
558-200 Harness Injectors
558-105 Harnes main unterminated (104 if you want a V8 terminated)
558-402 Harness AUX J2B (outputs)
558-401 Harness AUX J2A (inputs+wb02#2)
558-308 Harness Power
556-111 BBC Crank Trigger Kit
2pc 554-101 Wideband
538-24 MAP-sensor
9920-107 Air temp sensor
534-10 Coolant temp sensor
554-102 100 psi Fuel
554-102 100 psi Oil
8pc 556-112 CNP Coils
120-00003 Efi connection cam plug
Injectors
Drivers for Nos if you want the progressive
Harness for CNP if you dont make your own. I prefer to make my own on high HP cars as i need more Cable area for these dwell settings.
Best luck!
The Holley 558-307 CNP main harness is for Holley's CNP smart coils and LSx coils.
If using Holley's 556-112 CNP coils, Holley's 558-312 CNP coil sub-harness is also required.
For LSx coils, the Holley CNP main harness plugs right into the two GM 12579355 CNP sub-harnesses.
Discussion Starter #13
its a 540 t106 turbo was a blow through changing to dom efi alcohol. motor made 1640HP with 16lbs boost 6500 rpm talked to mike moran and going to use 1 set of his 500# injectors he said good to 2000 hp.whitch is fine for now internals are only good to 1800 or so any way
Just took the msd 7531 out and changed over to the holley coils. Here is most of the stuff i recall.
You can use your crank trigger and the distributor for cam sync signal. Good idea to swap out your magnetic crank sensor for holley part 554-118. It is a hall effect sensor that will thread in place of the current one. Less chance for any interference using hall effect. Depending on the distributor it may need a slight modification for the cam sync.
The holley coils use a different wire end then the ls coils. They are the hei style end.
Also the power and ground wires feeding the holley coils will need to be 10-12 gauge vs the smaller one provided in the ls coil harness 558-307. Verify coil harness wiring is correct as holley had some harnesses that were incorrect.
Buy your accessory ecm connectors now. You will end up needing them. You can buy 558-408. Comes with connectors and pins. You will need to supply your own wires to crimp the pins too.
It's a 540 T106 turbo, was a blow through, changing to Dominator EFI...
Since it's not an LSx application, you'll need all three parts in post #9.
They will be enough. I use 70% of mine and only on 75psi base pressure. It in the mid 6:s with 1273kg Weight.
Discussion Starter #19
thank you guys for all the info really appreciate it this whole build has been in a two car garage for a few years only thing farmed out was motor and trans every thing else was hand bilt by a friend of mine and a little bit me
1 - 20 of 34 Posts
