1 - 20 of 23 Posts
I have read the instructions pertaining to this. And it looks pretty good doing a test run in the shop, but not so much during a run. I'm using co2, dual mac valves, controlling two gates. Dome pressure sensor is "remote" mounted on a 4" long 1/4" DOT tube just to isolate it from the heat and vibration. Should I decrease "P"
58360
58361
58362
I have read the instructions pertaining to this. And it looks pretty good doing a test run in the shop, but not so much during a run. I'm using co2, dual mac valves, controlling two gates. Dome pressure sensor is "remote" mounted on a 4" long 1/4" DOT tube just to isolate it from the heat and vibration. Should I decrease "P" View attachment 58360 View attachment 58361 View attachment 58362
Yes. Drop the P to 10 or even less till the dome becomes more stable. Then if its a little lazy to react bump up the I term.
Mm yes but beyond just the line even
Say gate is closed and all the volume there is in the actual dome....
When the dome is closed say it is 100 units right
Say when the gate is open it is only 50 units
Can see as the gate strokes in normal operation how it makes it very tough to control. The volume is so small it is even sensitive to the actual fill and vent activity.
Now say you add the tank... And your total common dome volume is now 300 closed
And 250 wide open
You can see how this takes the gate stroking greatly out of the situation and the solenoid activity
It stabilizes the system massively
I run a small air tank inside the car... The solenoids feed the
Is tank.... The dome sensor is mounted in this tank..... And a single line comes all the way forward to the gate. That is it
It gives me control to do anything and perfectly. It is so stable I can run the dome control P all the way to 100 in actual operation and it will stay stable
Here is a typical example of mine to show you what can be possible
Now note that this is in closed loop dome and map.... Aswell
The stability I have in the dome controller is what allows me to use the second controller mint like this
There is zero channel filtering in the dome channel
So note in the top window what you are seeing is actual Target boost and actual boost in the Plenum
In the bottom window what you are seeing is the base dome commanded.....it's coming directly from the base dome table
And the second one is actual dome pressure
The difference between base dome an actual dome is how much the second map controller has pushed the system to achieve target boost
Discussion Starter #10
Looks like it works pretty nice. Just seems to me the mac valves would be maxed out trying to fill the tank / gates as needed to follow your target if there was an aggressive ramp to it. It looks like your target increased about 30 psi in 5.5 seconds. I think I'll give it a shot. Thanks for the input.
The slow ramp is just by mile per hour and my desired power management on the street.
Response is not an issue
Beyond old
^^ And, when you open the hood, cover the tank with a towel. Makes them say "WTF, is he hiding?
Discussion Starter #17
Before I had a Holley. I used a mechanical gauge with a tattletale hand on my exhaust. It was setting in my radiator support with a rag over it. Drove some guys crazy. One had his kid pull the rag off to see what was there, I was in the trailer but seen the hole thing. LMAO
That’s awesome
Discussion Starter #19
Built an accumulator. Leak / pressure tested to 160psi.
Put a schrader valve on the end so guys would scratch their head. Lol
Also for now I'm ruining my dome pressure sensor same as before. I'm not convened it being on the tank is best.
Sent from my iPhone using Tapatalk
1 - 20 of 23 Posts
