81 - 81 of 81 Posts
To Billy Godbold:
Lq4 6.0 408 stroker Ls7 heads
4.030 X 4.00 = 408
4500 TB & Super Victor EFI
12.4 Compression
1.8 ratio Ls7 heads
Crank scrapper
Gz Vaccum pump
Pump Gas 93 octane and or E85
Ls7 heads modified by Darin Morgan @ Reher Morrison @ the time now with BES
2.20 Titanium stock LS7 intake
1.550 Ferrea 24° exhaust
Flowed on 4.060 bore 28” TP
CFM
Lift No. 1 No. 2
0.2000 116.2 165.2
0.3000 169.2 238.7
0.4000 195.3 300.6
0.5000 213.8 336.2
0.6000 226.9 360.1
0.7000 234.8 379.7
0.8000 248.0 370.0
Looking @ 2 LST Cams
258 part #23324 (Intake Duration) .420 lobe
270 part #23374 (Exhaust Duration) .420 lobe
113 LSA 110 ICL
Or
274 part #23376 (Exhaust Duration) .420 lobe
113 LSA 110 ICL
2875 lbs Target Weight 2002 SN95 Mustang
4l80e No stall....
4.10/4.30 gear
Mostly Street Driven but some grudge NA
Thanks in advance 👍
RE: Lq4 6.0 408 stroker Ls7 heads
Billy Godbold
To
ANDRE LOSSEM
Aug 20 at 9:17 AM
The 2 degree earlier EO and 2 deg later EC will not make as big of a change as you might think. The smaller exhaust makes the converter stall a tiny bit less critical. If you moved the ECL out 2 degrees on the bigger exhaust (+1 LSA) the overlap would be the same and it would make more positive difference high, but with more penalty low.
Where are you on PTV. I can help more Tuesday if needed…
81 - 81 of 81 Posts
