1 - 3 of 3 Posts
Running the V4 30 build now, notice my oil pressure readings are 10 psi lower
than actual pressure. (LS 6.0) They dont have a GM choice for oil sensor, so I
used the Holley one. If i upgraded to the V5 and picked the GM sensor, would it
read more accurate. I tend to not upgrade as I screw things up. Theres prob a
way to do the custom one, but way above my pay grade, lol.
I was datalogging and noticed the OP looked low, the dash gauge read higher-i hooked up
a mech gauge and proved the HP reading was off-wierd, the turbo oil feed reads way low
at the turbo, but on the other end where the gauge is the pressure is fine-I was going to
try and download the v5, but screwed something up and lost the V4 and all the tunes, now
I cant even download ecu to laptop, somehow I have to get the V4 back-I was trying to put
the V4 tune in the v5, knew I shouldnt have touched it..
1 - 3 of 3 Posts
