Finally got the mustang inspected and on the road. During deceleration the car goes super lean 9.0-10 when the TPS is at zero. Once i give it gas and the TPS is anything above zero the AFR's come back up to 14.5 as i have it set in the programming. Self learning status and CL status goes from green to blue as soon as the TPS is at zero. What do i need to adjust to fix this so the car doesn't stay lean during the entire time of decel? I have a Pro Comp C4 3 speed automatic in the car. When im in decel and above say 30 MPH the car does this. Once i slow down and the converter isn't locked the car will idle at 14.5. Only at slow speeds. If i do pull to 100 mph the status goes blue and AFR's go down in the 9's until i'm under say 30 mph. I dont want to burn up my new build. Please let me know what i need to adjust! Thank you guys! - Gene
